Hello! Cant find any info about this, but when I try to convert this model from 3ds max to skp, it move everything out of place, theres a solution or a workaround for this?
HI.
Where did you get it, what format is it?
Hi, I thought that the only alternative is to create it from SketchUp is simpler, in fact I simply designed it and added some plants from the SketchUp library. The result is this:
Or download it in .obj format maybe when you import it into SketchUp it doesn’t separate
Thank you! I will try that way, btw I get the model from 3dsky. And yes is simpler, for that model I designed with the original model plants trying to get close to the original model
