hi, its me again! is it safe to delete these? what will happen if i delete this folder?
Hi @22-01854
The Pak file or the f2 folder is basically the D5 Asset data that you have used in all of your projects. Deleting them would lighten your D5 Folder, but you may need to update the assets upon opening these projects.
- It’s generally safe to delete them but the only catch is that there will be a window that appears every time you open your projects asking you to update these assets.
