In the new version of D5 2.10 in Rhino 8, the texture mapping does not translate - if you map something in Rhino, it wont pass onto D5.
I believe this is a bug, in the previous version it was working perfectly. This is a very big deficiency in the workflow.
I know the moderators here cant do much, but please, reforce the need with the teams for a fix ASAP, this is a bit bad.
Thank you!
Clov
2
Hi @edu.fon1
Can you provide images and the exact steps on how to reproduce this issue on our end? I tried it with Rhino 8:
- Cube Solid with Box Mapping
- Sphere solid with Spherical Mapping
Both of these textures were downloaded from the internet and are normally read by D5 Render after activating Live sync.
- Additionally please make sure that the material you have used is not labeled as “Place Holder” otherwise it won’t be read in D5.
