Custom wood boxes designs idea?
I’m thinking of making some wooden custom boxes out of plywood. These will be used to display some antique things. Something similar to https://customcraftltd.com/
Can anyone give me ideas on the best type and thickness of material? Also would these be best glued or screwed together?
Thanks in advance : )
Hi, you can use the material of D5 assets library to make the surface of wooden boxes, and then adjust the roughness and specular parameters in the right sidebar to make the wood surface smoother. :smiley:
