I can’t seem to get rid of the individual faces when applying a video to a curved screen. Any help would be appreciated. Using latest D5 version.
Justin
Justin
Hello, the problem with the model or video may cause the current situation. You can try to use the arc model in the assets library to replace the current model or adjust the smoothness of the model in the modeling software. This problem may be caused by a modeling error. If this method does not help you solve the problem, you can try to replace other videos. The format of the video can also cause this problem. ![]()
That was also my first idea but you can’t change the angle of the arc model. it’s always 180°. when trying to scale it you get a squeezed elliptic thing.
a new arc model wpuld be nice, where you can set an individual angle ![]()
Thank you for your suggestion, I have shared this suggestion with my team.
You can try to use the arc model in the assets library to replace the current model or adjust the smoothness of the model in the modeling software. After making these adjustments you can import the video into the model again. If the problem is not resolved, you can try using other videos on your current model.
Because the error of the model and the video will cause this problem. You can check which one has the problem by replacing the model or video. This can help solve the problem.
