I’m looking for an alternative to Blender. I create nighttime scenes of outdoor spaces, illuminated by specific lighting fixtures (path, flood, spot, etc.). The fixture is created in Fusion360, and I usually add the light element using Emission properties with an IES node in Blender. Then manipulate beam spread and color temp - resulting in an accurate depiction of the fixture’s properties. Can I do this in D-5? Is there a tutorial? Looking forward to becoming a part of this community.
Hi @rstellar
I’m not sure if this will satisfy what you’re looking for but recently in 2.11 version we have supported the following:
13. Added IES Lighting to Point Light and Area Lights with Support for IES Intensity
- Added IES controller to Point Light, Strip Light, Rect Light, and Disc Light. The loading method and controls are consistent with those for Spotlights.
- Added the “Apply IES Intensity” option which automatically reads and applies the brightness information from the IES file when enabled.
- Supports showing the IES light range indicator in the viewport.
Supports syncing IES profiles of Corona lights and Photometric lights using D5 LiveSync for 3ds Max.
And as for Blender, we recently updated the plug-in
