Create objects out of PNG images
Hi!
How was this object created?
I have many PNG images of people that I would like to make objects, the same as we see trees above.
What would be the best practice of doing it?
If you use a D5 2D person and use the material picker , you can replace the color map with your own people pngs . They will rotate with the camera . If you are wanting to do a background plane, go to D5 basic models down at end of online library and add the png tree image . All these objects can be added to your local library when you are done
