Hi, I created an animation (timeline) for a small shock absorber assembly. I’ve animated one of them, but in the model I have multiple instances that should be animated at the same time. Is there a way to copy the shock absorber as an object along with its entire timeline?
Currently, D5 Render doesn’t have a direct function to easily copy timeline animations from one object to its instances if the animation was created natively within D5. However, if you animated the shock absorber in another 3D software and imported it into D5 Render using the Alembic (.abc) format, then the animation data would be included and could be instanced.
