Is it possible to copy only specific parameters?
For example, can I copy just the camera position without transferring anything else to another scene?
Pretty sure D5 doesn’t have this feature yet, but you could try saving the scene as a template or duplicating the project, then adjusting only the parts you need. It’s not perfect, but it might help transfer the camera position without affecting everything else.
Hi there,
We have yet to incorporate this feature, but I think it will be a good addition in subsequent releases. You may also want to try @huntermorrow3301’s suggestion, as it may be the current workaround. Nevertheless, I will forward this suggestion to my team. Thank you for sharing your insights.
Perfect, thank you. This workaround is ok.
