Hello everyone
I would like to know if there is a way to create lights in scenes that will stay with a permanent configuration.
Example: I make a (scene 1) of a house during the day with lights off on the walls at 6:00 pm. Then I do another (scene 2) of the same house but turning on the lights on the walls and placing the sunlight at 4:00 am.
When I return to the scene (scene 1) of the day house, the lights on the walls should be off, and there should be sunlight at 6:00 pm but it’s not like that… I have to set everything up again
Hi, for different scenes in the Scene list, D5 can record the hidden/shown status of lights so you can turn on/off lights by hidding/unhiding them.
But they cannot have different values for other parameters, like light intensity or radius, etc. It is currently not supported.
You may have mistakenly turned on the function of “Camera Switch only”. When this function is turned on, only the location of the camera will change with the scene, and the environment and lighting settings will not change.
This function can be turned off according to the instructions of the picture. This is the reference article of “Camera Switch only”:Want scenes to have different vibes? Turn off Camera Switch Only
