with a laptop ryzen 9, 64 gb ram and rtx 3080 16 gb, i have a lagging issue in a small interior scene. I work in best camera mode view but still, the scene is very small.
do you work with 4k / 2k monitors?
I use two 2k monitors (RTX 3070).
if i work with D5 at 2k the high resolution scene is slow. if i set the resolution to fullhd i have no problems.
hi @danygasnier1
4k / 2k display is one of the problems
Please also provide your graphics card driver version,and please try to upgrade to 511
is use only laptop resolution 2560x 1600 px
i use refresh rates 165 hz
change your screen resolution from windows monitor settings, set it to fullhd (1900x1080)
Are you plugged in when you use your laptop?
yes i m plugged but lowering resolution seems to fix the issue
