ubject: Compatibility Inquiry for D5 Render on Minisforum Neptune HX99G
I’m planning to purchase the Minisforum Neptune HX99G mini PC, and I’d like to check its compatibility with D5 Render. Here are the key specifications of the PC:
- CPU: AMD Ryzen 9 6900HX
- GPU: AMD Radeon RX 6600M (8GB GDDR6)
- RAM: Up to 64GB DDR5
- Storage: NVMe SSD
Since D5 Render is optimized for NVIDIA RTX GPUs, I’m concerned about whether it will run properly on this system. Will I be able to use D5 Render smoothly with this hardware, even without RTX support?
Thank you for your help!
Best regards,
