Hi how do you control color of the cloth material? I only put 1 orange base color map, but it won’t display the correct colors even the base color selection won’t diplay correctly. I already tried inputing different maps but still won’t do.
Thanks
Thanks
I already tried resetting the material itself but still won’t solve the problem
Change the color in the material color tab, in the screenshot you put orange in the map tab
Hello, the base color and base color map work together via multiplying calculation, like Base color*Base color map. So you could try to adjust the Base Color to pure white, then see the result.
hi sorry for the late reply. Yah it got fixed after I reset d5. Unfortunately I got another problem. When I reopen the file, the exposure became very bright. Even though I already have some shots saved in the animation tab. Thanks, is there anyway I can recover the file from it’s last exposure?
I kind of like the shade on the fabric, but I would look at something like this https://create.vista.com/colors/palettes/neon/
I’ve run into that too—it’s usually a shader or material setup issue. Double-check if your cloth material is using the right shader (like HDRP/Lit or URP/Lit), and make sure there’s no color tint or override in the shader settings. Sometimes even a plugged-in normal map messes with how the color shows up.
