Choice of the GPU to use with D5 Render
I have RTX 2080 in my laptop - this is default GPU.
I have also an external RTX 3080 which I want to use with D5 Render. I have a problem with that. D5 Render don’t see my secondary GPU.
When I disable my default RTX2080 and activate external RTX 3080 only and restart my laptop, then D5 can see my external GPU.
Can you please fix it so I will be able to choose my GPU to use with D5 Render without the necessity of restarting my laptop and disabling my primary GPU?
Hi there, thanks for posting. Does your external video card dock have drivers to set GPU for programs? Also, on Nvidia control panel, you can select GPU to run D5 Render, please give it a try.
Hi Oliver,
Thank you.
What do you mean by this: “Does your external video card dock have drivers to set GPU for programs?” I don’t understand this question.
I tried to select GPU to run D5 Render Nvidia on control panel. It didn’t work.
