Character and asset custom color
Hi…
For an animation, I need to turn all my character in bright white color for styling reason. I don’t want to replace them with the lowpoly asset… I want to change the color to juste have the silhouet in white, not only for fixed character but also for the animated ones. Is there an option for that?
Thanks
This is also a problem that I need to upgrade. “white people” sometimes my project requires white people, but D5 cannot do this yet. To fix this, I often use external models and post-process, causing heavy files. If white people can be updated in d5, that would be really convenient.
Hi there. Currently, D5 2.8 does not support such a feature since solid-colored assets are only available as Low Poly Models (Models, Vegetation, and Vehicle) . Nevertheless, we consider your ideas and requests invaluable and will convey this to our team. It would also be better for you to also post this idea in this category: Ideas and Request
Thank you for your continuous support~
