Changes inside the object
Is there a way to open and adjust an object from the library? Most objects in the library are in “closed groups”. That’s a real shame. Look at the example. I wanted to copy the sofa. Unfortunately the scarf is getting in the way. I would like to hide it or position the cushions differently. It would be nice if the D5 team made that possible. I’m sure many users would be grateful.
I am convinced that having objects saved as groups is something that needs to be implemented as soon as possible.
In the meantime, I recommend a temporary solution that can only be used to hide objects in the model. You can create a copy of the model, make it unique and apply a Custom Alpha material with a black Opacity Map.
In the example I have applied the custom alpha texture to the blanket and cushions
Thank you for your answer and help. The idea with the alpha material is very good.
Thanks for sharing your idea!
Thanks for your advice. I will convey your idea to our team. I think we may improve this in the future.
You can also post your idea in the ideas& requests channel in the forum.
Best regards
