I apologize for the inconvenience. I have tried to recreate the issue using the Demo Scene and inserted a Car path. It doesn’t seem to have the same problem as you have experienced.
Can you perhaps let me know the relevant steps for this?
Or which car assets were used?
This is the link to the test that I made: Car Test
If it is possible, you can send your D5 Scene FIles to us so we can assess it better. You may send it to support@d5techs.com and have it titled “Clov-Forum Car Path not smooth” Thank you.
hi, i have watched video carefully and noticed, all cars heading straight stops and jerks at specific area (that red color crossing) . check car path, is there any node point at that area of path. im pretty sure its issue of path node.
please check and inform any progress.
hi @visualplus thankyou for you insight! my path was one straight line without a node. What I noticed is that the car path had the ‘DROP’ activated, and the red stripe was 0.01 above the asphalt level, causing a bit of the problem.
@Clov I noticed that the cars now seem to slide over the asphalt, previously we had the RATE button to match the rotation of the wheels with the movement of the cars but i cant find it anymore. Was it removed?
We did not remove this feature. You can access the “Rate” parameter in “Video” preview mode. However, please note that this will only modify the individual vehicle asset, not the entire path.
