I think there is an issue with the normal glass material. I have a building object (raum.fbx) with several objects in it. Every object with unique material so I can select them in D5. Could also assign the glass to the doors. But once assigned, the glass material can no longer be selected with the material picker. The main object (raum.fbx) is not locked. Can select every other object except the assignet glass. Please help…
best regards
Michael
Hi @Albareus,
Please tell me the version of D5 Render. Which glass material in D5 Assets Library are you using?
If it’s convenient, can you send the scene file (The entire folder where the .drs file is located) to support@d5techs.com, and please describe the problem, I can check it for you. Thank you so much.
Rectification. The object can still be selected. But objects with transparent materials do not have a black outline. That’s why they look like they couldn’t be selected. I sent a more detailed description by e-mail.
