It looks like one of my materials has become invisible and I cannot find anywhere or way in which I am able to pick it again or make it visible? Hovering over doesnt pick up anything at all.
Hi @NOV
Could you please attach a screenshot showing how the issue looks on your screen? I’d like to confirm what you mean by “invisible” — is the entire model or object not visible in the preview, or has the material simply become transparent?
Also, please try using the Material Picker shortcut key (i) and see if D5 is able to pick the material when you hover over that area. Thank you
There’s a whole wall here missing. I was trying to apply a Opacity Mapped material to something in the model so that it would be invisible, I am not sure if it has affected this wall but currently there is no way to tell or pick it if it has.
Hi @NOV
Could you please try adding a base material back onto the affected geometry in your 3D modeling software and then resync it with D5? Check whether the wall’s material or opacity settings were altered and see if the wall color or visibility updates after resyncing. Thank you
