I am trying to recover save data from a project I am working on. However, it is greyed out. I checked the backup files and they are populated with information. How do I recover these files?
Hi, please zip your file then send it to support@d5techs.com. Do not open the file too many times now, or you can save a copy first, otherwise the backups may be overwritten.
Or you can try coping the files from the BackUp folder- backups( whose name contains the date)
then paste those fils into the project folder to replace the current files. You can do this for each of backups one by one to check whether one can work. Do not forget to backup your files manually before doing that.
