Hello
I’m new to D5 render and i can’t find the workflow palette in C4d after installing the workflow plugin
Yes i have already downloaded it and installed it’
Bt i can’t find it in C4d
I don’t know the program well, I know many others, and they have the same way of interfacing. But seeing the string above your image that you inserted, I would try to see on Extension. If you don’t find in that curtain try on the empty box, where there are the icons, with the right button, some entries for the program icons must come out. Type View, Templates, Volume, File, Edit etc… You can find the D5 string there.
I hope I have helped you
