Once I have selected the material from assets and applied to the surface, I can’t then click it and keep editing it. I have to reapply the material and edit it. Any ideas? I used to be able to just click any materials after I have applied them in the model and tweak the settings of each.
Hi @jonathanwall82, I apologize for the inconvenience. Are you able to see the inspector panel on the right side of your screen when you select the applied material? Have you tried using the shortcut key (I) to select the material? If possible, could you please send us a screen recording? This will help us troubleshoot the issue more effectively.
I @Anthony_D5 it seems i am currently experiencing the similar issues raised by the other user. how can i fix this? i will send a screen recording as well. it seems im unable to upload the recording.
Please generate a link with the video file on it, then you may share it here. Thank you.
Colective Log
Thanks for sending your files. I just tested it and it works normally on my end.
- I can select all the surfaces with the material picker
- I can also generate a scatter.
Video Recording: Unique Download Link | WeTransfer
Just some additional questions:
- Does it only occur to this specific file?
- Does reopening or closing the file still not solve the issue?
Anyway, we’ll be investigating this issue further with your logs + scene file. Thank you.
