Just experience it today. I can’t download any of the assets and models. I’m using a pro version.
Please help.
Please help.
have you received any update with the issue???
It seems to be associated with the internet connection, i tried changing where i connected and it immediately showed the assets with no problems. I tried changing it back to the former, and the assets went missing. I hope this works for you as well.
Unfortunately, this happens in some regions,
I have to use a VPN to get to work with my license, otherwise I will have the same issue.
Maybe some deeper investigation by D5 team would be nice
Hi @iphdesignstudio @h.maranan.525058
I apologize for the inconvenience. May I know which region you are in? And your internet provider? We are currently facing the issue of CDN node failure for the PH Region and are contacting the service provider to handle it. If you are not from the PH Region, please let me know. Thank you.
Yes I’m from the Philippines. Using Globe Telecoms.
May I know when will this issue be resolved??
I don’t have access to other networks… but will try to reset our connection
Thank you
Hi there,
We are currently contacting Globe and PLDT regarding this issue; we have already run some tests through my end since I’m also experiencing the same problem and from the same region. For now, I am using a ProtonVPN so I can access the Asset Library, you can use any VPN at your disposal (your preference). Again, we are so sorry for the inconvenience this issue has caused. Thank you for your understanding and patience.
do you have detailed instruction to follow so i can switch to protonVPN? I really need to submit several renders asap…
thank you
Hi there,
You may download the application through their official website and after the installation you can simply proceed to “Quick Connect”. You can check out their link here: Setup Guide for new users | Proton VPN
Thank you very much for the info… but i hope issue still get resolved asap.
