For some reason Candle Fire doesn’t work.
The size of the flame doesn’t matter. Nothing appears.
Could you tell me which asset or practice you used?
I use any item from the particle system, any fire from the suggested resource library. Firework, failing leaves, smoke, fire do not work for me. But Fluid works. Is this due to the fact that I use D5 with Archicad?
Uploading: Снимок экрана 2023-11-16 181533.png…
Uploading: Снимок экрана 2023-11-16 181348.png…
Uploading: Снимок экрана 2023-11-16 181238.png…
Although dynamics were enabled, for some reason dynamic objects did not work! I reloaded the scene many times, but nothing changed. Everything changed only after I pressed the button with the running man. I simply didn’t notice the hint that appeared. Unfortunately, not everything is translated into English.
Hello!
Could you please send your scene file and the link of this post to us?
(support@d5techs.com, and please describe the problem)
Yes, but now I opened the old, saved scene and everything worked in it. I did not do anything. I have a huge candle flame and a fire 01 object that I made just to test it out. I thought it was something with the scale of the stage, but it turned out not to be the case. I just clicked on the dynamic icon, although it did not change and remained the same (running man), but the fire immediately lit on the candles.
Thank you for the feedback. We will pay attention to it.
I understood why this happened. Perhaps when I used this object I did not have a pro account.
Could you tell me which asset did you use in this scene?
