Can we render transparent background?
I am trying to remove sky or HDRI from render.
This question was asked 2 years ago and that time answer is cannot. This is a main reason I cannot use D5 render regularly.
Is It possible to get transparent background from latest D5 version ?
Thank you for your help.
Hi Kwin,
You can remove the sky and the background by using the sky and material channel after you render the image.
Hope it helps
In terms of backgrounds, it would be good to be able to change the background color when not using HDR…currently it is white - sky; blue - terrain, don’t you think?
Thank you for remind me this function. Yes, it work.
However it would be nice if user can just render image with transparent background without rendering different mask layers to compose later. I don’t think D5 really want to improve this feature.
Yes, it would be nicer if user can choose any background color without using any mask to remove background and change it to another color background.
yes it really helpfull , like alpha channel of enscape
I was looking for this, but I am new using D5, can you explain more detailed the process? please
Just render your image with the sky mask element (tick the channel sky mask), open your image in PS, import the Sky Mask image, and use the magic wand to select the with area!
Beware that the sky mask also masks out semi-transparent windows. I use ImageMagick (under Ubuntu/WSL2) to combine the sky mask and the transparency mask. Then I apply the combined mask as an alpha channel to the render:
composite -compose Dst_In \( mask.png -alpha copy \) render.png -alpha Set result.png
Example:
Following up here - I’m new to D5 , coming from Enscape and really miss the ability to simply check a box on export settings to render the background as transparent (.png with back background). Everyone’s suggested workarounds with Sky Masks in Photoshop work, but for multiple images this is a tedious task and generates quite a mess of files to juggle.
