Can I import the D5 asset models into Rhino?
Is this possible?
It would be very helpful to have this feature since Rhino has the ‘Make2D’ command, which is very useful for creating technical drawings of the scene.
If I use the asset models from D5, this is not possible since the models are only used and present on D5. I would have to do it manually or simply not use the assets.
Has anyone found any way to “fix” this or a “work around”?
No, the d5 assets can only be used in D5 Render.
Yhup… I would love if we could place/use the asset library inside Rhino itself like Chaos Cosmos. Would be the V-Ray killer
