Twinmotion allows you to change the material of a wall or component even if it was exported with the same material being used in other parts. Is it possible to do this in D5? It would be exhausting to create types and edit Revit material layers every time I want to try different texture combinations.
I wish there was a way to export elements (let’s say walls - as an example) as separate elements from Revit. Currently, we have to either export geometry separately or manually assign a different material from within Revit
