Camera position in saved scenes does not render the same every time. Even with the same aspect ratio and resolution, it seems the camera shifts upwards or downwards depending of the proportions of the windows itself.
While working, I usually resize the d5 windows to half the screen, and other times I maximize the windows. So, some times the viewer looks vertical, and other times in landscape. The black bars that appear after choosing an aspect ratio, never render the same. It completely messes up the post production process
Hi, it seems like I’m still encountering this issue in version 2.6. When I create and set up a camera at a specific position, then save it as a scene, the rendered area always changes even with the same ratio, which is 4:3. I feel that with this ratio, the camera captures a wider area, but in the scene, it appears to be cropped.
Hello, can you tell me the version of D5 you are currently using? If possible, I hope you can provide screenshots of your problem. Also, are you using a higher version of the software to open a scene made with an older version? Since some parameters are updated between versions, this could also cause an offset.
Really sorry for this issue. Is it convenient for you to share your D5 scene file with us. You can share the link here directly or send it to us by email (support@d5techs.com, please describe the problem and attach the post in the mail).
Happening to me too. Out of 35 renderings for this project it only did this for 3 of them. Not sure why its changing the view and I have to start Post process from scratch. I can’t have this happen to my projects.
Sorry for this issue. Could you please share your scene file with us? You can share a link here or send your files to us by email (support@d5techs.com, please describe the problem and attach the link of this post to your mail).
