How can I optimize my camera please?
I ve got a lot of jerky when i turn around my project with my camera?
It’s not Fluid…
Thanks in advance
I d like to have a path for the caméra too,please .
Like in 3dsmax for animation properly a caméra.
Hi, @neoseb
Thanks for the feedback
There are some new optimization options. We are working on it.
You can make the turning angle larger to reduce the current problem
Thanks for your feed back.
i think a simple path for the camera will be perfect;)
Ah man yes please. I have had projects and am just about to start a project that would have been ideal for d5 render but I need much more control over the camera path to navigate around a room. I hope that this feature is given serious consideration. At the moment my only options are to render using blender/modo and octane which takes much too long or in after effects using element 3D which isn’t as pretty. The ideal solution would be d5 render with camera path controls ![]()
