Camera and lights
okay so whenever i open any on my saved D5 Files all my lights and camera move to a different position.
i am using max workflow.
and this has happening with all of my files every time I open, I have to re sync all the lights and camera, however settings and environment remains unaffected.
Hi, is this IES? Can you send this file to us for troubleshooting? does it only happen to these lights rather than other objects?
support@d5techs.com
thank you for the quick response. this only happens with every kind of lights. all the basic model and lights misaligns whenever i open d5 file.
i have mailed u the file
many other people also had the same issue back in 2020 also
is it fixed or am i doing something wrong here
Hi mate, thank you for your files but we cannot reproduce the issues you met. The model we synced from your max file is correct without the position problems. Did you move the models in D5 accidentally?
No mostly what happens is when I open D5 files directly then all the camera and lights misalign. if I sync them up from the 3ds max then the lights and camera remain at place, so for example when I make changes in this bathroom file and sync it, I will have to sync lights and camera again. even when I did not move the original file.
It’s weird, can you record a video to show the problem? to confirm, D5 version 2.5.1? max2020?
my d5 is the lastest but max is 2023.
Can you rename the max file and sync it again? We find the files are synced before according to your scene list. Sorry, we still cannot reproduce that issue :joy:. The converter is also the latest, right?
The only way i have found out is that i have to stop sync in max and close it and then manually adjust save the D5 file. may be i have some issue with my max. once i save d5 files and not sync max files all things work normally.
