C4D material not synced
  • Supports Redshift 3.5 (Supports the new node editor of Cinema 4D 2024/2023/R25 + Redshift 3.5.x and the node editor of Cinema 4D S24/R23/S22/R21 + Redshift 3.5.x)
Cinema 4D 2023.1.0 + Redshift 3.5.12 + D5 Sync 2.6.6.0029 = Material synchronization doesn’t work, any idea?
Hi @jdg1 ,
Did this issue happen just after updating to 2.6? Does it work normally before? Is it that all the materials from C4D files cannot be synced to D5?
If it’s convenient, can you send the C4D file and D5 file (The entire folder where the .drs file is located) to me or to support@d5techs.com?
Regards,
