I export an object with a texture from Max to d5. When I import the object into d5, the texture comes out blurry. But then I manually replace the blurry texture from d5 with the same texture and then it doesn’t come out blurry. Any idea why this is happening?
Hi, you don’t have a super resolution curtain on the left, because maybe but I’m not sure if you remove the problem. Then you also have to check the updates of the video card, this too you must check
Good work
Thanks.
Problem solved.
It happened because of the export settings from Max. I changed the resolution in the settings from 1024 to 4096 and now it’s fine.
There was a time when the problem was fixed by turning the widget “D5 SR Image” on and off.
