Hi. I have artifacts appearing on the final static images. Mainly on greenery. This appears at the same views at a resolution of both 4k and 8k. DOF is disabled. Some views in this scene work fine, but some are glitchy. Do you know how to fix it?
Apologies for running you into this issue. Could you please check if your D5 SR has been enabled? If that’s the case, have it disabled and render again. Turning off D5 SR has some setbacks like longer rendering time yet output quality remains intact and will not be downgraded.
If this issue hasn’t been resolved through this suggestion feel free to get back to me.
