What are those? Pls help
[viewport]
[final render]
[viewport]
[final render]
Sorry for your issue.
What’s your D5 version?
Does it occur all scenes or specific scene file?
Sorry I forgot the imformations
It’s 2.6.1
Model import from Sketchup
It occur all scenes
BTW I can’t open skp files after install D5 render
When I click on skp files, nothing happened.
After uninstall D5 and restart my laptop, skp runs normally
[My laptop: MSI GS66]
Win10
i9 10980HK
RTX 2070 SUPER Max-Q (latest video card driver version)
32gb DDR4
Were you using D5 2.5 version before? Did the problem occur just after upgrading to 2.6.1.0401?
I wonder know that are your files imported into D5 via the live plugin or are they D5 read-only? Do you still have this problem if you open an empty scene or Demo scene?
No , I’m totally new in D5.
2.6.1 version has the same problem with 2.6.1.0401 veriosn.
These two version can open normally in D5.exe & .drs files.
I did installed skp live plugin after I install D5 main system.
But within/without live plugin , it just can’t open skp while I connect to internet.
I can open Skp files and run D5 live plugin if disconnect the internet.
Sorry for my expressions, not good at english…
還是您會說中文!? 許先生/小姐
Will the blue/green dots appear when you open an empty scene or Demo scene?
If it is convenient, you can DM me directly or send the scene file (The entire folder where the .drs file is located) and your SU model to support@d5techs.com with the briefly describe. We will check it.
It won’t .
Pls check your message, I upload on google drive.
Thanks for your help ![]()
Problem solved.
UV intensity is too high, adjust UV scale smaller and the dots disappeared.
