So, I’ve just uploaded to 2.9, and now, everything that I had hidden in Blender is showing up when syncronizing, even If I try to show and hide them again. Now, the only solution I have is to delete those models, but I dont want to do that because I have several options saved to keep testing things like room distributions, roofs with booleans, exteriors with or without buildings…
I tried hiding only the objects, then only the collections where they are, then both at the same time. Not working, everything inside the file is showing no matter what and I do.
The same issue happens with other files.
Thanks ![]()
