I have several scenes in my file and each one has an aspect ratio.
When I put them all in the render queue, even leaving them all with the original aspect ratio, all the images in the final render end up having the same aspect ratio.
How to solve this or would it be a bug?
Hi, if I understand correctly, you make the scenes with different aspect ratios, and then you insert it into the queue folder, but it doesn’t appear when you render. But first, did you check in the queue folder that the images below have the characteristics of how you want to save the scenes?
If it doesn’t happen then when you give it at the beginning the size and the type of files to save, you have to regenerate the image, it’s as if it were a sort of saving, then insert it in the queue folder and check if it’s 2K, JPG or PIG files of any size.
See it this way.
Hello. Have you updated the corresponding scene in the list of scenes on the right side after setting the image scale?
