D5 Sync is not visible on the toolbar in the Archid Korean version, is this normal?
Hi @scoz,
After you install D5 Sync, will it show up here on Archicad? Can you take a screenshot for me?
have Archicad 26/27 kor version and
I’m using both Archicad 26/27 INT versions
D5 Sync does not work with KOR version only.
I’m attaching a screenshot above, so please refer to it.
(I’m using twinmotion Archicad ALL VER.
Hi @scoz ,
When you click the setup of D5 Sync for Archicad, does the option for Archicad KOR version appear in the pop-up window? If it appears, you need to tick it.
Please make sure you have both D5 Render and D5 sync for Archicad installed. Maybe you only installed D5 Render, not the D5 Sync plugin?
D5 Render for Archicad Real-Time Rendering Workflow
