I installed the D5 render live-sync on my Archicad 22, but no add-ons or pop-up box for d5 render. Eventhough on d5 render website says d5 supports archicad 21- 29, can you please help it d5 stil supprt archicad 22?.
Thanks
Hi @hnguyen1
Yes, Archicad 22 is still supported by the D5 LiveSync plugin, so it should work with your setup. If the D5 toolbar or add-on is not appearing in Archicad, it may be due to an installation issue or plugin activation. Could you please check the following:
- In Archicad, go to Options → Add-On Manager. Check whether D5 LiveSync / D5 Render appears in the list and is enabled.
- After installation, please restart Archicad to load the plugin.
- Check the Menu / Toolbar. Sometimes the plugin loads, but the toolbar is hidden.
You can also check out our User Manual here: Archicad | User Manual
