Antialiasing is awful
I rendered it at 2K, but the arrows are particularly dirty.
It’s the same when I render it at 4K.
Is there a setting to clean it?
Best regards.
Hi @mihi0315
I apologize for the inconvenience.
  • Have you tried disabling FPS Booster or Super Resolution?
    Super Resolution and FPS Booster
  • Also disable D5 SR Rendering widget since this feature may compromise the quality in exchange for Render Speed.
Let me know if any of these helped. Thank you.
Thank you for your reply.
I’ve tried disabling them all, but it doesn’t seem to have much effect.
Alright, I would like to test them on my end. Can you send the file right now?
I have emailed you the download link for the file.
Best regards.
I have emailed you the Google Drive link for the file.
Best regards.
Hi @mihi0315
We have tested your file, and it yields the same results. The issue lies in the overall anti-aliasing of D5 Render.
  • The anti-aliasing of D5 Render is set to be optimized in subsequent releases. For now, the workaround is to improve the quality of output images by rendering them at 6k or higher quality.
Thank you for your understanding.
Thank you for checking.
I look forward to seeing more in the future.
