Hi!
I’ve been having some alias issues on emisive material. Specially when applied to thin structures or splines.
Is there any way to avoid of fix that? Some glow effect eventually could help, but that’s just a
A clean install can help?
Hello, sorry for the issue. Is it convenient to take screenshots to show what kind of alias issues are there?
Hello!
These samples are from 1920x1080 images, the lines or splines measure 1 cm to 0.5 cm maximum width.
Adding a glow effect can help, but there are still noises and jagged edges.
The entire scene should be a bit dark so that the neon effect is more evident, the light comes from behind with no front lights.
Thanks in advance
Hello, @Javier_Villar
Is this the case for both preview and output? What is the intensity of the self-emission?
Please send us this scene file (The entire folder where the .drs file is located) to locate the problem at support@d5techs.com. Please attach a link to this post in the email.
yes, preview and output look quite similar.
Intensity is 30.
I’ve sent you an email
Hi have you found a solution to this problem ? I get a lot of jagged edges and not only on emmisive materials. I think d5 can do better quality.
