Animating articulated objects
I’d like to animate a light rail tram with a few articulations/sections that allow for sequential turning along a path. Is this doable in D5 if I import the set in four pieces?
Hi there,
I believe it is possible to achieve this in D5 Render, but the movement might not be very fluid or smooth. I encourage you to give it a try and share your results with us. Thank you!
