Hi!
I know D5 render should work well on both, but many apps are normally better optimized for Intel. How is it with D5 render, would it work better with Intel or AMD CPUs?
I am asking because I have 2 CPUs one with Intel and one with AMD (which has a CPU with a better overall benchmark and a better GPU and D5 render works smoother on an Intel CPU. Aperantly the GPU with AMD is somehow bottlenecked? Intel is better in
Single-Threaded Performance and AMD in Multi-Threaded Performance. Maybe for D5 render Single-Threaded Performance is more important?
Here are the specifications for both PCs:
PC1: (D5 with heavier files is laggy)
AMD Ryzen 9 5900X
DDR4 3600MHz 64GB
RTX 3070 8GB
PC2: (works smooth)
I7 12700K (not overclocked)
DDR5 4000MHz 64GB
RTX 3060ti 8GB
Both PCs are updated and GPUs have the latest drivers installed.
I thought that the PC with RTX 3070 would work better. It also has a slightly slower ram, but can this affect that much?
Why do you think a PC with a 3060ti and intel CPU) works better than a 3070 with AMD CPU)?
Also which CPU and GPU would you choose for a new fresh build?
Thank you!
