Hi! I’ve supporting D5 Render for years and never encountered this problem before, but from a couple of updates, the program takes like 10 minutes to open, just opening the program.
And after opening, when it’s about render, same issue. 10 minutes for a single render calculating, but just 30 seconds in the “real” render.
Does this occur to all of your files, or is it specific to this one? And does it occur every time you open this file?
As D5 has newly opened on a new version, it is expected to have a one-time longer loading time. It won’t happen again after you have fully loaded the program after the update; otherwise, it might be a bug that we need to investigate.
Please send us your log files + Scene files so we can test it on our end. You may send it to support@d5techs.com and have it titled 2.11 Clov-Forum Almost 10 Minutes for Opening D5 Render
It happens EVERY TIME I open the software. Just for opening the software… almost 10 minutes, and for opening a project, more than 15 minutes every time.
Again, it’s just opening the software, not opening NOTHING.
I did that two times with the same result: NOTHING. So no, I won’t send anything, losing my time doing something that you should be doing for a long, reaaally long time. Especially according to the software month price.
I tried EVERYTHING. I even changed my graphics card, and the problem is still there. Yesterday I was working at 120 fps, and then, suddenly, it dropped to 6 / 8 fps… I waited like 5 minutes and then came back to 80 / 90 fps. Nothing changed, using scatter, trees, grass…
Same file, same project, performance drops to a nightmare.
Same problem for years. Probably a memory leak, but it’s not my job to fix that problem.
