When I use AI in post-process, there are some cases that it will improve some of the people. Are there any settings or workarounds to improve the People using the integrated AI? Thanks
Hi jake.p, I have the same issue to report. Even if people are quite big on the picture, they are sometimes not adjusted.
regards
I apologize for any inconvenience this issue has caused. Have you tried using the AI Enhancer with Specific Content? This will enable you to select specifically the parts of the image to enhance hence, you can select the character to ensure that they are part of the enhancement.
Hi Clovisbolasco14,
Thank you for your answer. I have tried different options. Only marked the people and also enhanced the whole image with AI. The problem occurs in both cases. I know that the faces should not be smaller than 200x200 pixels so that they can be recognized by AI. But even then they are not always recognized correctly. But I have the impression that the problem has not occurred as often in the last few weeks.
regards
Hi @Albareus
Can you perhaps send us a screenshot of the images that you were able to produce? If it’s possible you can either tell us how to replicate the issue or send us your D5 Render File (you may send it to support@d5techs.com and have it titled Clov-Forum AI on People) Thank you.
Hi @Clov ,
Thank you for your reply. I will get back to you, but please be patient. I have a lot of projects to do right now.
regards
