AI generated renderings stretched
Is there anything that can be done about this?
After generating AI Style Transfer ( based on external reference file ), the size of the generated file is slightly stretched compared to the original rendering. Each time, overlaying both files becomes troublesome, so the AI image needs to be shrunk / stretched.
Is there a way to do this? Why do the generated AI images behave this way? (Only the width is changed…)
Hi @arch.pxl
I apologize for the inconvenience. This is currently a known issue.
  • Using AI Style Transfer default templates will have a less noticeable resize compared to having it based on a reference image.
We are currently fixing this issue and will address it in subsequent releases. Thank you for your understanding.
