I have a problem using AI Enhancement
Image size 4k It’s very slow.Slow both when calculating images and when downloading 1 image, almost 40 minutes. But the rendering speed is normal.
i5-10500
RTX4070
RAM32
Is it related to HDD capacity? Because when I use it to plant a lot of trees, my hard disk will be full.
The anomaly and fix happened today, could you please try again now?
Does this issue only happen when using AI Enhancer? Does it also happen to other features that require network connectivity (e.g AI Atmosphere, Text to 3D etc)?
How long did it take to download one enhanced image?
Thank you for the quick reply @Leah_Li .
I just rendered a 4k image and enhanced it with AI Enhancer. The AI calculation took 5 minutes and 35 seconds. The download took over 22 minutes. It’s not because of my internet connection. It’s fast. The download should normally take a few seconds.
Now that I’m using it, it’s still slow. Loading image files was slow. 1 image used AI and downloaded more than 1 hour, but the rendered image took less than 3 minutes.
Just for confirmation, do you mean the enhancement process is fast (several minutes), but loading and downloading the enhanced image takes a long time?
In the picture sent the purple tube is fast.
After that, there will be a preview of the images. It will gradually preview from top to bottom. This part takes more than 40 minutes and downloading images also takes a long time. It is a problem during the evening time in Thailand.
I noticed something strange. For the first time, the download was finished after a few seconds.
As soon as the download started in the “Preview”, I clicked “Enhancement Tasks” and then on download. The image downloaded quickly. But the image in the preview still took a long time to load.
Okay, thanks for the detailed description, It seems to have something to do with the unstable connection. We’ll keep an eye on this as well and keep collecting related feedback.
Could you also provide your network speed within D5 for me?
this figure shows your network speed is very slow , have you tried restarting your router or switching to a different network, or testing with your hotspot? Does the slowness only happen when using AI Enhancer? Does it also happen to other features that require network connectivity (e.g AI Atmosphere, Text to 3D etc)?
Besides, what’s the resolution? Do you have lots of images in your enhancement tasks list?
Unfortunately, I can’t change the connection in the office. The IT department is responsible here.
But at home the OSS speed is much faster and the download of the AI images is still slow.
It really depends on whether more users are using AI at that or if your internet connection is not too stable. These factors affect the AI Speed, but I don’t think using it more regularly makes it slower.
