account login through D5 launcher stuck on cloudflare verification
Hi there,
I cannot log in to my D5 account through the D5 Launcher, because the login window is endlessly loading the cloudflare verification without success.
Same situation with trying to log in through D5 render.
The login on the D5 website works without problems, though.
  • no VPN
  • no proxy
Anyone facing the same issue?
Hi @steffenhildebrand
Sorry for the inconvenience. May I know if you are able to log in now, or does the issue still persist? Thank you.
Hi @ela , yes still the same: when opening the login window, the cloudflare verification gets stuck in an endless loop…
Is there any prompt aside from the Cloudflare verification stuck in a loop? Could you please show me a screenshot of your login window? Thank you
this cloudflare verification usually takes only a few seconds, then it shows a tick in a box, then I can put in my password and continue to log in… but this verification is going endlessly…
  • no proxy, now vpn, no firewall…
Could you please try using a different network and attempt to log in again? Let me know if it works. Thank you.
