[3.1] Menu display glitches after update
Please send me update to resolve this flickering im on a deadline big project
So far, so good. Sometimes I notice it slows down a bit, but it comes back and everything works fine. The improvement has been about 95%. The interface is working perfectly. I’ll keep you updated on any changes.
hi Clov, same issue here, when are you planning to realease the hotfix? could you pls send me the build meanwhile? thanks a lot!
Hi @pakus68
The hotfix is currently in grayscale release; you should be getting the update prompt today or a few days from now.
  • Please try to log out of your D5 account then relog-in, and ensure that you’re selecting the PRO or Individual Identity.
thank you! lookinf forward to the hotfix…ai enhancer still works but the flickering is crazy))
Hi @Clov
I am also having the same issue. Can I please get the hotfix as well?
thank you!
so today 04/08 I did the upgrade with the official release online and…the issue is still there in the AI inhancer (((
Hi @pakus68
Could you please specify the issue you are experiencing? Are there small blocks showing in the AI Enhancer window?
  • If possible, please send us a screenshot to help us understand the context better.
  • If your reply pertains to a different issue than the UI glitching, I will create a new post for it.
A post was split to a new topic: UI Flickers even with 3.1 hotfix version
