As you can see, some 2d people is half black display issue ( im using real sky sun light )
Hope D5 team can fix it ASAP !!
Hello, to confirm, you are using 2.1 official version, not beta version, right?
Could you repro this issue in other scene file or a sample scene file? Sorry we did not repro this issue, could you please send a sample scene file which has this problem to ziyin.zhu@d5techs.com?
We will look into this asap. Thanks in advance!
im using 2.1 pro version, i cant send the scene because this is company project.
Hello, ok, no problem. The problem happens to this specific file, right? If you put those 2d characters to another scene or an empty scene, can you repro this problem?
one more thing, problem happens with ariel view, no problem happens with eye level view
This issue is still exists. If I update silhouette with the replace object funktion (or replace it manually of course) the black line / area disapears from the surface of the silhouette. When I update the model from archicad the black lines / areas come back. It’s really annoying and dangerous in complex projects. Please help!
Sorry for any inconvenience caused. When did you create this file? Did you use beta version? Can you send the scene files (The entire folder where the .drs file is located) to me? I will test it from my end and you can DM me directly or send to support@d5techs.com, please annotate you are from Forum in the email, so I can quickly find you. Any update will be appreciated.
