Cause: If we set glass materials as the focus of depth of field, the object behind the glass will be recognized on the same plane as the glass is. Even if the object is far away, it will be clearly displayed in the picture.
Solution: In this scenario, try not to select glass as the focus. You can select objects near the glass as the focus, and the view will return to normal.
